Welcome to C&C 27 Association Online Users: 81
Navigation C&C 27 Association General discussion Negative Ground?
Current Replies for Negative Ground?
  Negative Ground? (sony2000)
Posted: 4:17:19 pm on 6/24/2011 Modified: Never
Gentlemen, I have a C&C designed project boat (Paceship 29). Looking at the vacant Atomic 4 engine room on a rainy day, I thought I would try to make some order in the dangling wiring. If I can hook up the battery, and have some juice going to the fuse bar, some life might come back to the old girl.
From the battery selector two big black wires are close to the battery shelf, and a third big black one goes to where the alternator should end up. I recall a small wire coming from the inside of the battery selector.
Any help would be greatly appreciated.
  Re: Negative Ground? (windyday)
Posted: 5:11:24 pm on 6/25/2011 Modified: Never
Before connecting to a battery, I'd suggest drawing a full schematic of the existing wiring to sort out existing wires and potential current flows. Old boats are so often modified by previous owners. Not sure about the dangling wiring, or those 3 black wires. When we did our refit, I consolidated all the wiring, ending up with only one ground wire on the engine block leading back to the engine's main battery on/off switch, and only one ground wire from there to the engine start battery. We also have a ground bus for other circuits. Some alternators ground through their bolt point to the engine block, some have a dedicated ground wire, and if that black wire is DC ground, then it might possibly be part of another circuit, like the alternator's regulator. Hard to tell from here. Hope that helps a bit.
(Since we also have a house battery, we actually have a dual switch system to allow for emergency battery combining, but that's another matter.)
