Welcome to C&C 27 Association Online Users: 67
Navigation C&C 27 Association General discussion Wing on wing crew balance/mark V
Current Replies for Wing on wing crew balance/mark V
  Wing on wing crew balance/mark V (copasetic)
Posted: 3:07:12 pm on 8/11/2011 Modified: Never
We should have figured this out by now.Dead downwind, we  sail wing on wing with one crew sitting on the forward hatch, the driver sitting to leeward (defined as the boom side). Where should the jib/whisker pole trimmer sit?copasetic
  Re: Wing on wing crew balance/mark V (JWente)
Posted: 9:46:48 pm on 8/15/2011 Modified: Never
In light winds we heel the boat to windward by having skipper and crew on weather side - weight as far forward as you can, but not forward of the mast
in heavy wind - still heel to windward, but weight back in cockpit.
and usually someone sitting on the boom in all weather
they are really sensitive to weight placement - watch your knot meter as you move weitght around to get the fastest position.
