Welcome to C&C 27 Association Online Users: 137
Navigation C&C 27 Association General discussion Discolored Interior Teak
Current Replies for Discolored Interior Teak
  Discolored Interior Teak (firefly)
Posted: 5:33:55 pm on 10/28/2011 Modified: Never
I would like to refinish my interior teak. My boat was built in 1972 and I don't think it has been done previously. At some locations there has been water intrusion that caused the wood to sort of bleach out and appear lighter than the surrounding wood. Has anyone dealt with a similar issue? Should I stain the light areas prior to applying the oil finish? Does the teak oil help make the overall appearance more uniform?
Thanks for any suggestions.
Chuck Roe
San Francisco
  Re: Discolored Interior Teak (ALAN FORD)
Posted: 9:55:39 pm on 10/29/2011 Modified: Never
There have been some previous thoughts on this subject, most recently on 9/9(2011) under the heading "Mildew on interior teak". 'Search' for that heading and it may help you decide what to do. The lemon oil does no harm, allows you to do something else if it doesn't work for you, and is not a time-consuming project.
Good luck
