Welcome to C&C 27 Association Online Users: 14
Navigation C&C 27 Association General discussion 110V Panel Lamps
Current Replies for 110V Panel Lamps
  110V Panel Lamps (Tonyj)
Posted: 10:38:40 am on 2/24/2012 Modified: Never
Hi:
I have a few damaged indicator lamps on my MkV 110v electrical panel.  I'm not sure how to remove them. I'd appreciate any suggestions.
Mk V #581
FLYING CIRCUS
San Diego
  Re: 110V Panel Lamps (ALAN FORD)
Posted: 4:02:05 pm on 2/29/2012 Modified: Never
Tony, do you know if your 110v system was installed by C&C, or was it something that a previous owner wanted and installed later in FLYING CIRCUS's life? I'm curious as SMOKE has no such luxury, which might indicate that 110 v was not in C&C's original thoughts for the Mk V.
  Re: 110V Panel Lamps (Tonyj)
Posted: 5:56:29 pm on 3/1/2012 Modified: Never
Hi Alan:
It sure looks like a factory install to me.
Here's a photo:  http://www.jibeho.org/110vpanel.htm
Regards,
Tony
  Re: 110V Panel Lamps (Steve Reid)
Posted: 10:10:22 am on 3/2/2012 Modified: Never
From the photo it looks the same as the 110 V panel on Still Knot Working. C&C did offer an optional 110V Shore Power system as a factory installed item. you might want to try South Shore Yachts for the replacement parts you are looking for.
Still Knot Working MkV #75
Posted: 11:23:43 am on 3/2/2012 Modified: Never
Thank you Tony and Steve, now I am jealous . Having the prototype gives a little sense of history,  but also let's you see what  C&C found in need of change or addition once they had one Mk V going.
