Welcome to C&C 27 Association Online Users: 36
Navigation C&C 27 Association General discussion Backflow into toilet bowl
Current Replies for Backflow into toilet bowl
question Backflow into toilet bowl (dmartis)
Posted: 2:44:39 pm on 5/28/2012 Modified: Never
I have a mystery of water flowing back into the toilet bowl of my new Jabsco toilet. The original toilet did this, so I of course replaced it, as well as new hoses.  I replaced the polyethylene tank (that had numerous cracks) with a new stainless steel tank.
Inspite of my efforts, some of the liquids destined for the tank end up back in the bowl, with associated unpleasant odours. I checked the joker valve, and it still looks brand new.  I pumped the bowl dry with the water intake closed, and still water somehow gets in.
Does anyone else have this problem? I've read about vented loops at the top of the discharge hose, but I'm not sure if this is necessary yet.  Is this a venting issue?
Dan Martis
Dream Catcher
Mark 3, Hull #636
  Re: Backflow into toilet bowl (Steve Reid)
Posted: 6:32:13 pm on 5/28/2012 Modified: Never
You might want to check your holding tank vent. It may have become plugger over the winter. If the vent is plugged and the tank won't vent you will build up presure in the tank when you pump from the toilet into the tank. That pressure could be causing the liquid in the tank to be forced back through the lines and into the toilet.
Try removing the deck pumpout plug and pump some water from the bowel and into the tank, let it sit for a period of time and see if it comes back into the bowel. If it does not then your vent is most likely plugged.
  Re: Backflow into toilet bowl (dmartis)
Posted: 1:14:31 pm on 6/4/2012 Modified: Never
Definitely a good idea - I gave it a try and still have water in the bowl all the time.  Must be the joker valve - hard to believe its worn out already!  Has anyone ever installed a vented loop at the top of the discharge hose? Or should the joker valve be able to hold back any residual liquids from draining back into the bowl?
Dan Martis
Dream Catcher
Mark 3, Hull #636
  Re: Backflow into toilet bowl (Tonyj)
Posted: 5:45:45 pm on 6/4/2012 Modified: Never
Hi Dan:
Yes, you should install an anti-siphon valve (vented loop) in the discharge line.
Here's Don Casey's article on head installation:
http://www.boatus.com/boattech/casey/installing-head.asp
He recommends a vented loop.
Good Luck,
Tony Jeske
FLYING CIRCUS
Mk V #581
San Diego
Posted: 7:08:08 pm on 6/4/2012 Modified: Never
Dan:
I would be very careful about installing a vented loop in your system if it is connected directly to a holding tank. Vented loops are only recommenrded in systems that have a direct overboard discharge.
By putting a vented loop in your system you are exposing yourself and everyone on the boat to the possibility (a very real concern) of the release of fumes and gasses from the holding tank. Your holding tank must have a vent hose that is connected to a vent on the exterior of the boat, this allows for the expansion and contraction of the contents of the tank and allows for the escape of excess fumes and gas form the tank.
  Re: Backflow into toilet bowl (ALAN FORD)
Posted: 11:56:12 am on 6/6/2012 Modified: Never
Last week I had abnormal pressure when pumping out the contents of the bowl to the holding tank, and then had the good fortune to read Steve Reid's comment about blocked ventilation lines. Yesterday I removed two large, dead wasps (hornets???) and their nest/ bedding from the outside fitting and now that extra pressure has gone. Thanks Steve. Cause of death of those beasties was asphyxiation.
Posted: 1:42:06 pm on 7/16/2012 Modified: Never
Turns out it was the joker valve, even though it was just over a year old.  Apparently you need to replace these things every year.  New $10 valve - presto, no backflow!
On to the next project.
Dan Martis
Dream Catcher
Mark 3, Hull #636
