Welcome to C&C 27 Association Online Users: 137
Navigation C&C 27 Association General discussion mounting new head
Current Replies for mounting new head
  mounting new head (Chivas)
Posted: 3:25:12 pm on 6/3/2012 Modified: Never
Hi there, I have a 1985 MK V and the Brydon head is kaput. I am going to mount a Jabsco head in its place. My question is: does the platform that the head sits on have plywood under the fiberglass? And can I just set the necessary inset bolts in the floor and bolt done the new head?
Stephen Hnatyshyn
Chivas & Champagne, Mk V
Nepean Sailing Club
Nepean, ON
  Re: mounting new head (oasis)
Posted: 4:30:20 pm on 6/3/2012 Modified: Never
I just did mine on my 1987 Mk V.  There is plywood under the fiberglass.  I just drilled new hole, plugged the old ones, and used the old lag bolts the old head was bolted down with.  Reconnected the hoses, and away it went.  Took less than 1 hour.  There is a thread somewhere in the Black Arts showing a picture of a Mk  V where that owner drilled approx 2 inch access holes in the vertical face of the platform the head is mounted on to get at the underside of the surface - he found some plastic plugs used in electric situations to act as removable fillers.  I did not find that necessary.
Barry, Oasis, 1987 MkV
  Re: mounting new head (Chivas)
Posted: 4:52:10 pm on 6/3/2012 Modified: Never
Thank you very much! Rather than insetting an inset bolt in the platform it sounds like I can just lag bolt it down.( presently the head has bolts coming up through the foor with acorn nuts securing it down, not what appears to be lag bolts pinning it down)
Thanks again Barry.
Steve.
Stephen Hnatyshyn
Nepean Sailing Club
Nepean, ON
  Re: mounting new head (JWente)
Posted: 6:38:33 pm on 6/4/2012 Modified: Never
the lagbolts holding my head down stripped out of the plywood
I cut a access hole in the front of the platform, and thrubolted the head.
