Welcome to C&C 27 Association Online Users: 133
Navigation C&C 27 Association General discussion MkV holding tank
Current Replies for MkV holding tank
  MkV holding tank (stargazer)
Posted: 8:26:52 pm on 9/7/2012 Modified: 8:28:53 pm on 9/7/2012
what would the approximate time be before requiring a pump out? I know this is entirely dependent on usage but if I could get some input here would be great
I'm having bowl backup to what I believe is abnormally premature
thanks
Lawrence Katz
'86 MkV #132
Lawrence Katz
'86 MkV #132
Stargazer II
Newport Yacht Club
  Re: MkV holding tank (Steve Reid)
Posted: 10:48:25 am on 9/8/2012 Modified: Never
Lawrence:
You should never have sewage backing up into the bowel. Even if your holding tank was compleatly full (not a good thing to have happen) any excess should come out through the vent (on the port side of the hull). If you are getting back pressure on the discharge hose from the toilet to the tank then you most likely have a blocked vent line.
  Re: MkV holding tank (ALAN FORD)
Posted: 10:02:46 pm on 9/8/2012 Modified: Never
Lawrence, this Forum is full of threads which relate to holding tanks and backing-up toilets!! It's a recurring problem it seems!. A recent one starts on 5/28/2012 and may be helpful.
