Welcome to C&C 27 Association Online Users: 37
Navigation C&C 27 Association General discussion CC27 out of water for winter
Current Replies for CC27 out of water for winter
  CC27 out of water for winter (Anna69)
Posted: 10:01:53 pm on 10/1/2012 Modified: Never
Any CC27 owners have their boat out of the water for the winter yet?  I am looking for the height from keel bottom to deck top. My rough estimate is 10ft but just looking to firm that guess up.
  Re: CC27 out of water for winter (bosco)
Posted: 7:19:08 pm on 10/2/2012 Modified: Never
This has come uo before --
See
Hey R.
This web-page has a link to another C and C site where you'll find an "Alladin's Cave" of info.  Among that stuff is a copy of the original C &C 27 Mk 111 brochure giving the mast height above the water as 41 feet. I've never measured  it but have always used  this number for clearance under bridges and power lines--- There's a marina nearby which I can't get to with Aragorn --- the power line strung across the entrance there is too low .
Given that the "P" figure for the Mark 111 is 31 feet, if you measure from the gooseneck fitting ( "x" feet)to the mast step, you can easily figure the distance from the mast step down to the waterline .
41 - 31= 10 feet from the gooseneck to the waterline minus "x" =  above water height of the hull . Add the draught of 4 ' 6" and you'll find you needed clearance ( except  that the hatch cover is a little higher than the mast step and as Dave suggests , you'll need a bit of room under the cradle as well)
 Clare Jordan Aragorn
