Welcome to C&C 27 Association Online Users: 67
Navigation C&C 27 Association General discussion Parting out Atomic 4 and assessories
Current Replies for Parting out Atomic 4 and assessories
  Parting out Atomic 4 and assessories (sony2000)
Posted: 12:02:24 pm on 9/24/2013 Modified: Never
Due to a defective piston, the rest is for sale.
Mechanical gauges, controls as well.
Water pump 202M7 rebuilt.,
Facet gas pump and check valve.
Prestolite distributor. etc.
  Re: Parting out Atomic 4 and assessories (malurd)
Posted: 5:55:43 pm on 9/25/2013 Modified: Never
Hello,
Did the piston damage the head?  Also what is the serial number for the engine?  You can contact me rick.ulam at gmail dot com.  As you can see I changed the email slightly to avoid spam.
Rick
Rick Ulam
Presque Isle, PA
1972 Mk I
  Re: Parting out Atomic 4 and assessories (whippet)
Posted: 9:15:45 pm on 9/26/2013 Modified: Never
what part of world you live in?   if Toronto, i am in need of starter motor and some other bits.
What do you plan to replace it with?
1981 MkIII, Hull 886
Etobicoke YC, Toronto ON
  Re: Parting out Atomic 4 and assessories (sony2000)
Posted: 11:11:31 pm on 9/26/2013 Modified: Never
I'm in Montreal, QC.
The replacement will be an electric motor. The C&C designed P29 has a V-Drive setup, and CB. Because of the CB cable, I've decided not to reinstall an internal combustion engine.
The starter is available.
