Welcome to C&C 27 Association Online Users: 160
Navigation C&C 27 Association General discussion Soft Deck
Current Replies for Soft Deck
question Soft Deck (AlbemarleQueen)
Posted: 9:53:50 pm on 3/11/2014 Modified: Never
Hello All,
I have a Mark 3 and have run into a bit of an issue with the deck. It is soft in placed and I know needs to be recored. I have all of the materials and have done a core replacement on two other boats. Here is my problem.. My last two coreing projects were on trailer boats that I could take the mast down without a problem. I don't have alot of space where my boat is stored now and having the yard take my mast down would cost a fair amount of money. The soft area is around my starboard side main stay. Is it advisable to do the deck work with the stays still in place? I know the deck is not necessarly structural in that area but what I don't know is if I can do the work with the rig still up. Thoughts anyone?
Brad N.
S/V Albemarle Queen, Mk III
Barnegat Bay, New Jersey
  Re: Soft Deck (Tonyj)
Posted: 10:42:26 am on 3/11/2014 Modified: Never
Hi Brad:
You could attach your halyards to the toerail, they'd serve as temporary stays while you did your core repair.
Good Luck,
MkV #581
FLYING CIRCUS
San Diego
  Re: Soft Deck (bosco)
Posted: 4:45:36 pm on 3/11/2014 Modified: Never
Hey Brad,
If you decide to use your halyards in place of shrouds, I suggest you lead them through blocks at the toe-rail and back to a winch and cleat.  That way, you can control/adjust  the tension.
Clare Jordan.  Aragorn
