Welcome to C&C 27 Association Online Users: 112
Navigation C&C 27 Association General discussion battery charging system
Current Replies for battery charging system
question battery charging system (Sailorone)
Posted: 5:45:19 pm on 9/13/2014 Modified: Never
Hi I purchased the Blue Sea ADD a Battery kit which comes with the battery switch and automatic charging relay (ACR). Has anyone else installed this withe the A4 and are there any additional wires not shown on the instruction sheet that I need to be concerned with? Thanks for any help.
Mike, Captain of the Blue Star
Ottawa, ON
  Re: battery charging system (bosco)
Posted: 7:39:54 pm on 9/14/2014 Modified: Never
Hi Mike, sounds like you are depending only on the instructions provided with the kit. If you google "blue sea", as I did, you'll find a wealth  of diagrams, diagnostics, installation tips  etc. for each of their systems as well as FAQ's
Clare Aragorn
  Re: battery charging system (Sailorone)
Posted: 8:08:44 pm on 9/15/2014 Modified: Never
Hi Clare
I have been all over their website but found nothing better than the small inboard wiring diagram on the instruction sheet. I also emailed Blue Sea directly. They had nothing to add beyond what is on the diagram as well. So perhaps I am complicating this for nothing.
On a different note, I added the high temp and oil pressure warning system from Moyer Marine. Except for having to purchase a few extra brass fittings, that went in well. Should help prevent future overheating, a minor problem I had last summer.
Thanks for your input.
Ottawa, ON
Posted: 8:45:02 pm on 9/15/2014 Modified: Never
Mike, did you find
www.bluesea.com/products/7650/Add-A-Battery_Kit_-_120A . .??
Much more here than an instruction sheet
Clare
Posted: 8:15:11 pm on 9/16/2014 Modified: Never
Yes I did go through all of those information sheets. But as they did not show an inboard motor I dismissed them. I will take a second look. When I get it all done, hopefully this fall, I will fill you in. Thank you again.
Ottawa, ON
  Re: battery charging system (davidww1)
Posted: 11:07:31 am on 9/17/2014 Modified: Never
Note that the captions above the circuit diagrams ("Batteries isolated", "Batteries combined through ACR", "Batteries combined through Battery Switch") are mouse-rollover controls that show the effects of different switch positions. They should be better identified, but once you find them, they give you a lot more information than it initially seems.
Posted: 7:38:01 pm on 9/22/2014 Modified: Never
I will look into that and hopefully find any missing info that I need. Thanks.
Ottawa, ON
