Welcome to C&C 27 Association Online Users: 172
Navigation C&C 27 Association General discussion Mast Step Removal
Current Replies for Mast Step Removal
  Mast Step Removal (bjarki)
Posted: 1:43:40 pm on 4/18/2015 Modified: Never
Does anyone have experience removing and resealing the mast step plate on a Mark 3? I found some water dripping through this spring and want to remove the mast step mounting plate. There are 4 bolts. The 2 aft bolts are very accessible, but the forward bolts (countersunk) seem to go into an inaccessible area in the boat. There is a possibility they attach to captured nuts, but I do not really want to chance it.
Any suggestion from someone who has had to do this before?
Bjarki Hallgrimsson
SKAL CC M3
  Re: Mast Step Removal (bosco)
Posted: 3:53:37 pm on 4/18/2015 Modified: Never
Hi Bjarki,
 I have had no experience removing the mast step, but I have experienced a ' drip' in this area . It turned out to be leakage , not through the mast step, but rather, water was passing through the aperture just a few inches aft of the mast step where the wiring for the mast systems passes though the deck. In my case , the water followed the wiring down and forward a few inches and dripped out of the cover plate which covers the aft rear of the mast inside the cabin.
Could this be your source too ?
Clare Jordan. Aragorn
  Re: Mast Step Removal (davidww1)
Posted: 9:31:02 pm on 4/19/2015 Modified: Never
I removed my mast step (to drill a mounting hole in the side) some years ago so my memory is hazy. I think the "inaccessible" bolts are in fact very long wood screws that extend into the bulkhead below. I didn't find any indication that there was water entry.
I second what Clare has said about the wiring holes. The bedding compound on the deck gland breaks down every few years, as does the wire-to-gasket seal in the gland.
  Re: Mast Step Removal (bjarki)
Posted: 10:29:56 pm on 4/20/2015 Modified: Never
That is very good advice and it makes sense. I will try to investigate that further with a hose. Incidentally it has been raining today and no new water, kind of strange so perhaps it was really a winter accumulation.
