Welcome to C&C 27 Association Online Users: 29
Navigation C&C 27 Association General discussion Prop Puller
Current Replies for Prop Puller
  Prop Puller (doogymon)
Posted: 9:35:59 pm on 6/1/2015 Modified: 10:20:25 pm on 6/1/2015
Any testimonials on what type of puller and techniques?
I have a fixed two blade with 1" shaft.
Can the C-Clamp style do the trick?
Much obliged.
Doog
  Re: Prop Puller (davidww1)
Posted: 12:36:40 pm on 6/3/2015 Modified: 5:59:27 pm on 6/3/2015
Prop pulling normally only is problematic with some folding props. Almost any puller will do for a 2-blade fixed prop. The C-clamp style with a screw bearing on the centre of the shaft is preferable to the type you hit with a mallet.
I'd double-check that shaft diameter (not that it's particularly relevant to this task); most 27's have a 7/8" shaft.
  Re: Prop Puller (doogymon)
Posted: 2:22:43 pm on 6/3/2015 Modified: Never
Hi David
Thanks very much.
Pretty sure 1" shaft.
Ok so I'll try to beg borrow or buy a C Clamp style.
Would make one if I had the time.
Cheers
Doog
SunnyJ
#827
Posted: 12:52:56 pm on 10/17/2016 Modified: Never
David
You were correct.
7/8" Shaft for my Yanmar YSM12.
Also Left Hand screw.
I scored a new Martec MKII (New Old Stock) 1" bore.
There is a company producing bushings to reduce the prop bore size.
http://www.propshopinc.com/Propeller-Bushing-7-8-Shaft-Anchor-Bushings-p19.html
Going to give a go. Hope the Yanmar can spin the 14" folder (9" Pitch).
Cheers
Doog
