Welcome to C&C 27 Association Online Users: 48
Navigation » C&C 27 Association » General discussion » wheel mounted autopilot »
Current Replies for wheel mounted autopilot
  wheel mounted autopilot (Rene)
Posted: 12:39:47 pm on 5/12/2016 Modified: Never
I am new to the forum. I am looking to purchase and install a Wheel mounted autopilot on LaVoie Lac T 1979 Mk III. Any suggestions on a particular model? I have just installed a garmin 721 GPS chartplotter.
thank you for your help.
René Lavoie
C&C 27 1979 MK III
Welland, Ontario
  Re: wheel mounted autopilot (wrapper)
Posted: 2:45:30 pm on 5/16/2016 Modified: Never
I am in the final process of installing a Raymarine Smart Pilot wheel installation.  Just finished the mechanical parts and it was not as bad as I was expecting.
The wheel part is the most complicated and it was quite easy.
The electronics is next and that should be a breeze.
My boat is all Raymarine, so I don't expect any problems.
Allan
Cygnus
C&C 27 Hull 518
  Re: wheel mounted autopilot (Rene)
Posted: 11:57:54 pm on 5/16/2016 Modified: Never
Thank you Allan I will look into it.
René Lavoie
C&C 27 1979 MK III
Welland, Ontario
  Re: wheel mounted autopilot (doogymon)
Posted: 10:24:31 pm on 5/17/2016 Modified: Never
I have a wheel.
But I use a Tiller Pilot with adapter (from an old Tillermaster)
Works like a charm.
Less complicated and less expense.
I have a spare on board.
Both are Simrad TP10 and bought used.
These units are robust, less complicated and easy to disengage (physically lift off at adapter end).
Cheers
Doog
Posted: 10:58:58 pm on 5/17/2016 Modified: 9:02:09 pm on 5/18/2016
Would you be able to send me photos of what that might look like?
If so send to [deleted]
Thank you
René Lavoie
C&C 27 1979 MK III
Welland, Ontario
[There is one rule on this Forum: no soliciting of private responses unless for the purpose of buying or selling something. When the conversation happens in the Forum, we all learn, which is the point of having a public Forum. Please read this explanation. As to exchanging photos, there are several suggestions in the page linked above (free sites like Flickr, etc.), or you can send them to me and I will make a Black Arts page if they are suitable.- Admin]
  Re: wheel mounted autopilot (carriden)
Posted: 2:04:39 pm on 5/18/2016 Modified: Never
Hello René
I am currently in the process of installing a Garmin 721 onto Carriden.  How did you handle the mounting?  If I mount it onto the pedestal guard above the compass, I will need to relocate the control head for my Raymarine Autohelm and so far I am not happy with possible alternate locations.
Posted: 5:06:50 pm on 5/26/2016 Modified: Never
Running the new Raymarine wheel pilot all weekend.  Super easy.  Practically no calibration.
Allan
Cygnus
C&C 27 Hull 518
