Welcome to C&C 27 Association Online Users: 123
Navigation C&C 27 Association General discussion Spinnaker Pole Mast Ring Height
Current Replies for Spinnaker Pole Mast Ring Height
  Spinnaker Pole Mast Ring Height (doogymon)
Posted: 11:37:07 am on 5/30/2016 Modified: 9:53:48 pm on 6/2/2016
Hello
Can anybody recommend a proper height for mounting a ring on the forward face on my mast?
Cheers & thanks
Doog
  Re: Spinnaker Pole Mast Ring Height (Tonyj)
Posted: 10:29:31 am on 6/5/2016 Modified: Never
Hi;
On my Mkv, the pole is 33 inches above the deck for use with a symmetrical spinnaker.  However, if I want to use it as a whisker pole, it needs to be lower. This would also be the case if you're flying an asym. The Mkv has a movable ring, so its ready for any use.
You'll have to drill holes to mount the fixed ring. Consider drilling a few more and mount a short piece of track on the front of your mast, which will allow a movable ring and more options for you.
Good Luck,
MkV #581 FLYING CIRCUS
Silver Gate YC San Diego
  Re: Spinnaker Pole Mast Ring Height (doogymon)
Posted: 2:32:33 pm on 6/5/2016 Modified: Never
Hi Tony
Thanks very much for your experience.
Maybe a track is the way to go, more fastening points
into the mast.
Cheers
Doog
