Welcome to C&C 27 Association Online Users: 48
Navigation C&C 27 Association General discussion Blue smoke in exhaust
Current Replies for Blue smoke in exhaust
  Blue smoke in exhaust (vtxrider55)
Posted: 12:59:24 pm on 9/14/2016 Modified: 3:51:58 pm on 9/14/2016
I noticed some blue smoke in the exhaust. Can't say that I have noticed it before, just bought the boat at the end of last summer and didn't really see any smoke till now.
Just wondering if this is an issue, or could be an issue?
Roy
Scorpios Two
C&C 27, 1971, hull #17
Forest City Yacht Club
Cleveland, Ohio
[Our Forum software is older-generation and does not give good feedback when it's digesting a post. Please give it a minute before clicking 'Submit' a second time. Duplicate post is now deleted. - Admin]
  Re: Blue smoke in exhaust (doogymon)
Posted: 8:09:06 pm on 9/15/2016 Modified: Never
Hi Roy
What make and model is your Iron Genny (engine)?
Cheers
Doog
  Re: Blue smoke in exhaust (vtxrider55)
Posted: 10:07:43 am on 9/15/2016 Modified: Never
Sorry about that, I should have mentioned it.
Atomic 4 , most likely original engine, 1971. I just don't remember seeing any smoke last season (bought the boat at the end of the season, or even seeing any smoke this season.  I did fill up the oil to the "full" mark a couple of weeks ago, and did not go over the fill line. If that helps.
Roy
Scorpios Two
Cleveland, Ohio
  Re: Blue smoke in exhaust (capricous)
Posted: 1:13:21 pm on 10/22/2016 Modified: Never
Look at the forums at Moyer marine
Great resource
http://www.moyermarine.com/
Dana
Marblehead Ma
Capricious Mark 3 Hull #599
Posted: 1:39:50 pm on 10/22/2016 Modified: Never
Will do, thank you!Roy
Scorpios Two
Cleveland, Ohio
  Re: Blue smoke in exhaust (BillSalton)
Posted: 8:37:22 pm on 11/27/2016 Modified: Never
The type of oil you use can make a difference. Moyer Marine seems to like straight 30 weight (I use Castrol Heavy Duty SAE 30), or 10W30. When we purchased our 27, 10 years ago, the owner had been using a synthetic, and our engine didn't like it! She was smoking and left a nasty oil slick behind the boat. We switched to the Castrol, and the problems went away, and we have a happy engine now.Bill Salton
Mark III, Whisper
SCBC, NOTL
Posted: 10:12:20 pm on 11/27/2016 Modified: Never
Hi Bill,
Thanks for replying!
That is a very interesting observation about the oil and thinking back about it, I did add oil and to be honest, I can not remember what type of oil I put in, most likely something on sale. I did not have smoke in the beginning of the season and later on I did, most likely after I added the oil!
For this season its too late to do anything about it since the boat is out, but I was planning on draining the oil in the spring and start with a fresh batch.
I will most definitely be using the Castrol Heavy Duty SAE 30, as you suggested!
Thank you for taking the time to respond to this, I appreciate it.  Roy
Scorpios Two
Cleveland, Ohio
  Re: Blue smoke in exhaust (whippet)
Posted: 12:02:28 pm on 11/28/2016 Modified: Never
You will find a debate on the Moyer site.  Some like 15-40 Rotella.  Claims of higher oil pressure.
Original A4 manual and Don Moyer himself points to 30W.    I use the Castrol 30W and works great for me.
Hope all clears up.
1981 MkIII, Hull 886
Etobicoke YC, Toronto ON
Posted: 12:06:04 pm on 11/28/2016 Modified: Never
Hi Steve,
Thanks for commenting. Now I feel bad that the boat is on the hard for the winter, very curious to see how the Castrol 30W will work, etc.
I will be doing some more reading of the manual as well.
Thanks again!
Roy
Scorpios Two
Cleveland, Ohio
