Welcome to C&C 27 Association Online Users: 13
Navigation » C&C 27 Association » General discussion » wiring harness for 79 mk III »
Current Replies for wiring harness for 79 mk III
  wiring harness for 79 mk III (Rene)
Posted: 4:37:16 pm on 2/12/2017 Modified: Never
I am looking at changing the wiring harness on my 79 mk III.  Not sure where to look for parts for this boat.
Can anyone help with a supplier?
René Lavoie
C&C 27 1979 MK III
Welland, Ontario
  Re: wiring harness for 79 mk III (davidww1)
Posted: 11:31:59 am on 2/13/2017 Modified: Never
First, why? Is the existing wiring damaged by mishandling? Corroded? Or is the issue just that a PO has added a lot of substandard wire and daisy-chained low-quality wire onto existing circuits? This is a lot of work, so I wouldn't embark on it without good reasons. Obviously, if the old wire is damaged, it has to go, but if it's just a matter of cleaning up cruddy additions, you might be happier limiting the scope of your ambitions to fitting a sub-panel and running good-quality wire in a workman-like way.
Can you be more specific about what you mean by "wiring harness"? If you mean literally the wire that runs through the boat and its connections, all you need to do is find a store that sells Ancor wire (each strand is tinned, so it won't corrode). If you don't like the expense of Ancor, use automotive wire, which you can buy at any automotive supplier. (In truth, this is probably adequate for a boat that will spend its life in fresh water.)
Think carefully about how you will run the wire before you start. On my boat, a lot of the wiring was laminated into the underside of the deck before the inner overhead skin was attached. There is no way to feed wire between the two unless you'd like to completely disassemble the boat, so you have to find other routes that are high and dry.
If your ambitions are greater (new fixtures, new switch panel & breakers), that's a whole new topic. You'll probably learn a lot by reading some of the advice on the West Marine web site (and given where you are, their Buffalo store is probably your supplier of choice, too).
  Re: wiring harness for 79 mk III (Rene)
Posted: 12:49:43 pm on 2/13/2017 Modified: Never
I should have more specific.
I am talking about the wiring harness from the ignition to the fuse panel.
and the reason is that I had a broken exhaust pipe just under the cockpit and melted the wires together.  I just noticed that the whole thing is a harness and ends with a connecting part just before the gauges in the cockpit.
René Lavoie
C&C 27 1979 MK III
Welland, Ontario
Posted: 1:18:11 pm on 2/13/2017 Modified: Never
Check through the Moyer Marine catalogue. I didn't see a harness specifically listed, but if they don't have it, doubtless they will make one up for you. Their prices are quite reasonable.
http://www.moyermarine.com/index.htm
  Re: wiring harness for 79 mk III (Katara)
Posted: 7:40:47 pm on 2/14/2017 Modified: Never
Rene,
I have an ignition panel and a harness , you're welcome to it . i think you are 6 docks away from me .
Gerard Warner
Katara, '79 Mk III
D.Y.C.  Ontario
Posted: 9:08:38 pm on 2/14/2017 Modified: 10:04:22 am on 2/15/2017
That would be great.
How do we proceed?
Am i able to share my cell phone number with you on this forum?
905 732 8324
Cheers
René Lavoie
C&C 27 1979 MK III
Welland, Ontario
[Soliciting of private responses is permitted for -- and only for -- the purpose of exchanging things (buying, selling, giving). So this phone number is fine. If you don't know why we have this rule, please read this explanation. - Admin]
Posted: 9:47:40 pm on 2/14/2017 Modified: Never
i can leave it at the club for you to pick up  ?
Gerard Warner
Katara, '79 Mk III
D.Y.C.  Ontario
Posted: 9:52:01 pm on 2/14/2017 Modified: Never
Great, I will come by the club on Friday.
René
René Lavoie
C&C 27 1979 MK III
Welland, Ontario
