Welcome to C&C 27 Association Online Users: 27
Navigation » C&C 27 Association » General discussion » Max prop »
Current Replies for Max prop
  Max prop (capricous)
Posted: 5:31:22 pm on 3/28/2019 Modified: 5:11:30 pm on 3/29/2019
Wondering if anyone that has a max feathering prop knows the pitch and set numbers for it.
Black arts has one at 28% is anyone's different
Thanks in advance
Dana
Capricious Mark 3 Hull #599
  Re: Max prop (larrybayer)
Posted: 8:44:15 pm on 4/5/2020 Modified: Never
Hi Dana; I've had a Max Prop on Yogi since the early 90's and love it. Can't remember the exact pitch and the manual with my info is on the boat and our Club is off limits at the moment. But I do know that I use" TBN" as the placement for spinners on the hub. I think this is either 14 or 16 degrees pitch? Leaning towards 16 but not certain. I have the Atomic 4 and played with it quite a bit. This is optimum for my boat. Good luck and let me know how you make out and like it when you finally get in the water.
Larry Bayer
Yogi Bear, Mk III
Niagara-On-The-Lake, ON
Posted: 8:47:33 pm on 4/5/2020 Modified: Never
Forgot to mention. I purchased mine brand new and the spinners were marked wrong from the factory!!! Drove me nuts for a bit till I figured that out!!! Hopefully yours aren't and I'm sure this was just one of those flukes either marked first thing on a Monday morning or last shift Friday!?!?
Larry Bayer
Yogi Bear, Mk III
