27 MK V rudder structure (SAILAVIE) Posted: 1:43:41 pm on 10/24/2019 Modified: Never
Hello C&C'ers
I am looking for my C&C 27 MK V structure, is it steel and foam ? solid wood ?
Thanks for your help
Marc DuboisMarc Dubois C&C 27 MK V 1988 hull 152 Marina d'Oka Oka, Quebec www.SailÀVie.ca
Re: 27 MK V rudder structure (JWente) Posted: 6:44:57 pm on 11/5/2019 Modified: Never
Hi It is a Fiberglass outer shell - the join is at the leading edge of the rudder Top part out of the water is painted white over the fiberglass I believe the interior is foam
There are currently
515
contributors
registered on the
C&C 27 Association
This Forum is supported by C&C 27 owners like you whose membership in
the
C&C 27 Association makes possible this Forum and the accompanying site.
Thank you, members, for your continuing commitment.
