#1 2003-12-10 23:46:53
Doug
Weather Stripping
I have a C&C 27 III with original fixed aluminum port frames.  I am installing new plexi.  I have the butyl tape and new plexi.  Does anyone have a line on the weather stripping that is inserted in between the aluminum frame and the plexi.  I am in Toronto.  Have sourced it at one place however was surprised at the price.
Doug Heldman
Quicksilver C&C 27 III
Doug Heldman
#2 2003-12-11 05:38:19
Re: Weather Stripping
I bought mine from Holland Marine Products, 3008 Dundas West
Toronto. Phone 416-762-3821.
Also available from North Shore in Niagara  on the Lake.
C&C 27/2   " Budge "
#3 2003-12-11 05:38:24
C&C 27/2   " Budge "
#4 2003-12-24 01:14:39
Doug
Thanks for the tip Bob
Not only do they (Holland Marine) have it on their web site.  It is also less expensive than the other supplier I sourced it at.
Cheers!
Doug Heldman
Doug Heldman
#5 2004-01-28 01:44:13
How much was the weatherstripping and where did you get the plexi and at what cost?
Bruce Peever
#6 2004-01-28 10:29:06
When I purchased from Holland marine in 2001, the cost for the butyl tape and gasket was $ 91.74 Can.$ taxes included. This was sufficient to do all windows.
The plexiglas was purchased from Laird Plastics in Hamilton Ontario at a cost of $28.75 Can.$ taxes included. Laird Plastics have a number of locations in the Toronto area. However I am sure it is available from other plastic suppliers. I used the old windows as templates to cut the plastic to size.
Hope this helps.
Budge C&C 27/2 Hull # 322
#7 2004-01-28 10:32:25
Doug
Bruce
You will find the weather stripping on the home page at Holland Marine <A href="http://www.hollandmarine.com/">http://www.hollandmarine.com/</A>
I checked several places and they have the best price.$2.89/ ft.
The plexi I sourced at "Ace Glass" a glass and mirror company in Scarborough (Toronto).  I thought it would be easily available at many spots like auto glass shops however it takes a bit of phoning around before you find the right place.  If you are in Toronto area call Ace.  I belive they charged about $65-$70 for tinted plexi glass. The Boat Show suppliers I checked with were all significantly higher.  The butyl tape that installs between the fiber glass and plexi glass I got at an auto glass place for free.
Doug Heldman
Doug Heldman
