#26 2007-11-06 03:57:48
wrapper
Re: 1976 mark 3 parts
How is the boom?
Where is the boat (geographically)
Allan boats(at)wrapmation.comAllan
Cygnus
C&C 27 Hull 518
Allan
Cygnus
C&C 27 Hull 518
#27 2007-11-06 11:43:04
ok except for corrosion on the back casting i am in nj
                                           thanks mike
#28 2007-11-06 12:28:18
phillips
Just wanted to see if you had a chance to get some pictures of the wheel, I'm very interested in converting my tiller to a wheel. andrewphillips(at)hfx.eastlink.ca
#29 2007-11-14 04:42:12
Reading the trail of messages I am not sure if you have sold the port-side aluminum casting (fairlead mounted at the intersection of the transom and port gunwhale) and used to secure the turning block for the spinnaker sheet/guy?
Mine has recently broken.
Sorry to hear of the said task of breaking up a boat.
Trevor (dot Nightinagle at NRC dot CA)
#30 2007-11-14 07:06:54
i sold those
#31 2007-11-14 07:06:55
i sold those
#32 2007-11-14 09:09:40
pura vida
I do have the port casting available. I will send photos.
#33 2007-11-22 00:22:47
mike m:
if you still have the port stern casting still available, i want to buy it.
Sorry so late getting back to you, its been crazy around here.
please e-mail me with how you would like to do the transaction.
thanks, steve penney.
<A href="mailto:stevep@nl.rogers.com">stevep@nl.rogers.com</A>
#34 2008-01-12 02:37:03
capricous
Do you have sails?Capricous
Capricious Mark 3 Hull #599
#35 2008-01-14 06:59:57
woodenr
do you have the original traveller car by any chance?
Bob
#36 2008-01-14 08:59:22
not sure do you have picture of original
#37 2008-01-14 09:01:28
only one thats any good is storm jib
#38 2008-01-14 13:04:20
woodenr
I am traveling so I don't have ability to get a picture...
The one I have (which I am pretty sure is original) has four wheels and a pivoting part in the middle that has the clevis for the sheet.  It is made by Nicro-Fico and runs on a track that is wider at the top and bottom and thinner in the middle.  I am going to stay with the original traveler for a while at least as it is OK and I have some decent controls on it that were added later.  My car has badly worn wheels, it I had a spare (even if it was also in worn condition) I'd try to replace the wheels with some new bearings...
Let me know if you have anything like that.  You can also reach me at rwooden at savvyconsultants dot com (adjsut as needed to standard format).
Thanks.
Bob Wooden
#39 2008-01-17 10:06:12
c&c27dyc
I have removed my original track, traveller car and end stop blocks.  Replaced everything with Harken.  Email on the Fleet page.
Dean M Baldwin
Morgan "D"
Mark III - Hull 516
Halifax, N.S.
Dean M Baldwin
Morgan "D"
Mark III - Hull 516
North Sydney, N.S.
#40 2008-02-05 05:46:18
How about the waste, water, and fuel caps.  The fittings were non standard on the older C&Cs.
Dave
<A href="mailto:davetanis@yahoo.com">davetanis@yahoo.com</A>
