#1 2009-01-10 03:54:21
Brent
Bottom paint quantity etc.
Greetings and happy new year C&C community.
Along with my colossal re-build list this spring I plan to apply a barrier coat to Wild Rover's hull and a coat of VC 17. Anyone there know what quantity I need of each for a MkV hull?
As well next year I'm going to do the topsides too. How much topside paint such as Interlux's two part polyurethane does one require?
Brent D
C&C 27 MkV #15
[Sanding/stripping of bottoms was an active topic a few years back. Use "Search" and terms like "barrier", "strip" and "interprotect" to find others' experiences and suggestions. - Admin]
Brent Driedger
S/V Wild Rover
C&C 27 MkV #15
#2 2009-01-10 04:26:07
Re: Bottom paint quantity etc.
Brent;  LAst year I striped Gemini (27, Mark V) and redid the hual. I put on four (4) coats of barrier paint and 1 top coat (Balto-plate).  Each coat took one gallon.  Petit recommends at least 4 coats for barrier.  That is right.  Most of us in the yard who do our own work, put on 4 coats, alternating colors (gray/white) to see what you have done.  It is a job, but well worth it when it is done!
#3 2009-01-10 08:59:46
windyday
I'm glad to get the 4-gallon confirmation. Here is my estimate for the order I just put in for Interlux Interprotect for our Mark II: overall length x beam x 85% = wetted surface area (better to actually measure it). Divide that by 60 for brushing to get gallons required to reach 10 mil thickness = 27.3 x 9.18 x 0.85 - 213.02/0.6 = 3.6 gallons = 4 gallons. I ordered two of white and two of gray.
#4 2009-01-10 09:01:06
windyday
Brent, when you say topside, do you mean the hull above the waterline to the toe rail, or do you mean the deck/coach roof/cockpit?
#5 2009-01-10 09:46:57
Brent
Hi and thanks for the replys.
By topsides I meant the hull above the waterline...not the deck.
Brent D
C&C 27 MkV #15
Brent Driedger
S/V Wild Rover
C&C 27 MkV #15
#6 2009-01-11 22:59:26
Hi, I'd put VC17 on my hull ( MV 1985 ). You will need 1 liters/coat ( 1 can in fact ). But don't put the mix into a pan because it will evaporate in a minute. Instead use an empty plastic bottle like dishwashing liquid, and then pour directly on your paint roller ( a small one, 4 inches wide ). With this method, only one liter will be enough by coat.
Jean Rivest,
Sorel-Tracy
[Alternatively, you can simply put your VC-17 in the freezer overnight and take it to the boat in a cooler. When cold, VC-17 loses its extreme volatility, so you can roll it out like normal paint. It also helps to paint early on a morning with little wind. Finally, don't throw away your tray and roller when you're done. VC-17 is based on a fast-acting solvent, so last year's roller will be ready to use seconds after you dip it in paint - and you don't have to worry about the lint that always comes out of new rollers (even the "lint-free" ones). - Admin]
#7 2009-01-15 13:23:07
Brent
Thanks all. Great advice. Now if only the stupid cold front would go away and winter come to a quick end I could get going on my obsession/project. I can't wait to sail her!
S/V Wild Rover
Brent D
C&C 27 MkV #15
Brent Driedger
S/V Wild Rover
C&C 27 MkV #15
#8 2009-01-20 11:41:15
clanning
I love those VC17 tips -- both the squeeze bottle and the freezer tips -- thanks!
Chuck Lanning
NSC, Ottawa
Chuck Lanning
NSC, Ottawa
