#1 2010-04-13 23:34:24
JWente
MK V Holding tank fittings
how are the inlet / outlet fittings attached to the holding tank - are they threaded into the polyethylene?
I just replaced the inlet/outlet hoses, and the fittings twisted in their seats.  Have I lost the seal?
Distant Thunder
#2 2010-04-17 14:39:01
Brent
Re: MK V Holding tank fittings
The holding tank on my MkV has threaded connections. If the barb by NPT 90 has moved a little during install you may be ok but keep this in mind, the MkV has many nooks and crannies below the holding tank for black water to get into and it's impossible to get out. The PO of my boat let the tank lid leak which spilled its contents while healing. I'm still trying to neutralize odors from those spots. It may be worth pulling the fittings and re-tape them just to be sure.
Brent Driedger
S/V Wild Rover
C&C 27 MkV #15
Brent Driedger
S/V Wild Rover
C&C 27 MkV #15
