#1 2013-12-21 05:34:27
PeterC
My rudder rotates 360'.
   I'm slowly getting my MK2 fixed up. I just got a new shaft and prop fitted for the electric motor I intent to install.I have realized that my rudder can rotate 360' when the tiller is raised, and would hit the prop. Is there a standard restraint system that should be fitted?
  Peter
Peter Connolly
Santa Cruz, Ca.
C&C 27 Mk 2
Peter Connolly
Santa Cruz, Ca.
C&C 27 Mk 2
#2 2013-12-21 23:52:15
Katara
Re: My rudder rotates 360'.
I think thats the design so the boat could do a 360 with in it's own length . thats also one the biggest changes made to the mk 3.
Gerard Warner
Katara, '79 Mk III
Bronte, ON
Gerard Warner
Katara, '79 Mk III
D.Y.C.  Ontario
#3 2013-12-22 00:02:37
bosco
Hi Peter, and Merry Christmas, from snowy, cold Canada
Don't know about the Mk II but my Mk III has a casting bolted to the front of the rudder post and this casting sits in a " notch" in the base plate of the rudder assembly through which the rudder post passes . The notch limits the rudder rotation to about 35 degrees off the centre line in either direction. Perhaps you're missing this casting ---Look for a couple of tapped holes in the front of your rudder post where the casting should bolt on.
Clare  Jordan Aragorn
Clare Jordan,
Stormont Yacht Club,
Long Sault
#4 2013-12-23 12:04:00
PeterC
  Thanks Gentlemen,
         It looks like I have a little engineering job to do. That swept back rudder when in reverse can whip the tiller out of your hand. Not a pleasant picture with my new prop. There is a casting on the front of the post, seems to be only to rest the tiller on, maybe a stopper key could be bolted to it and some kind of plate with a stopper fitted below it ...............?
Peter
PS; Just a sunny 65'F in Santa Cruz today..... but as I am Irish and have lived in Germany for years, I have had my share of rain and sleet and snow.
Peter Connolly
Santa Cruz, Ca.
C&C 27 Mk 2
Peter Connolly
Santa Cruz, Ca.
C&C 27 Mk 2
