#1 2005-03-18 08:08:40
TILLER HANDLE REFINISH
I HAVE A MARK V AND THE HANDLE NEED TO BE REFINISH. I HAVE REPAIRED AND SANDED IT SMOOTH. NOW WHAT SHOULD I DO.  KENNY
#2 2005-03-18 23:53:16
Re: TILLER HANDLE REFINISH
Don't know where you are, but if you keep a tiller cover on it, just varnish as any wood.  If you are in the tropics - use Bristol Finish (follow directions carefully), and still use a tiller cover for UV protection.
Warren Smith
Galveston Bay, Texas
#3 2005-03-19 01:40:19
Everyone will grouse at me but here goes:
1) Go to Home Depot---get 2 cans of spray varnish.
2) Put a string thru the bolt hole---hang it in the back shop.
3) Everytime you walk by---spin it---and spray.  After about ten coats---open the second can---and repeat.
4)  Then follow Warren"s advice.
I'm going sailing----11am Sat 72F <A href="mailto:NNE@10---Dave">NNE@10---Dave</A> in sunny Ft MyersDave Tinder
DAWN BREAKER  Mk3
Ft Myers
