#1 2009-01-24 05:33:54
moefahmy
Spinnaker measurements
This site specifies the SMW measurement for MK 3 at 21.15' (180%).  What about the luff measurement for symmetrical spinnakers? Is it the I measurement, i.e. 37'? and what would be the measurements for assymetrical spinnakers?  Any clarification will be greatly appreciated. Thanks
Mike Fahmy
<p style="MARGIN-RIGHT: 0px" dir="ltr">Kokopelli, Mk 3 # 735
<p style="MARGIN-RIGHT: 0px" dir="ltr">BYC, Ottawa, Ontario
<h5 style="TEXT-ALIGN: left">Mike Fahmy</h5>
<h5>Kokopelli, Mk 3 # 735 ; ; BYC, Ottawa, Ontario</h5>
<h5> ;</h5>
#2 2009-01-27 09:25:39
woodenr
Re: Spinnaker measurements
The old North spinnaker that came with my Mk 3 measures SMW 21.00; SL 35.5.  Lake Michigan shows the allowable as SMW 21.15 and SL at 36.88.  I'm not sure why this is a bit short of the I of 37.00...
I've flown the spinnaker a good bit for distance races and a foot longer or so would be fine.  If I have a new one made I'd make it close to 37.00 and lower the pole a bit.
Bob Wooden - Rhapsody waiting for spring in Wisconsin...
#3 2009-02-02 07:11:44
moefahmy
Thank you very much for your input Bob. I am surprised that the measurements are not specified in the class rules.  Does this mean that there is no restriction? I wonder!
Mike Fahmy
<h5> ;</h5>
#4 2009-02-03 09:21:48
c&c27dyc
<p class="MsoNormal" style="margin: 0cm 0cm 0pt;">Mike, class rules maybe not, but, handicap outings yes. Handicap reviews should be filed for; a) Spinnaker width greater than 1.8 times J. b) Spinnaker height greater than .95 times the square root of (I squared plus J squared). Basically more the 180% J
Dean M Baldwin
Morgan "D"
Mark III - Hull 516
Halifax, N.S.
Dean M Baldwin
Morgan "D"
Mark III - Hull 516
North Sydney, N.S.
#5 2009-02-06 15:01:05
moefahmy
Thank you Dean, if my calculations are correct, then the hight should be 36.88 or roughly very close to the I measurement.
When you refer to height, do you mean the centre of the sail or the luff-leech measurement? Some spinnakers extend downwards a foot or two at the centre.
Mike Fahmy
<h5> ;</h5>
#6 2009-02-10 01:07:45
c&c27dyc
Yes, your height ( luff & leach ) is reflective of your I. This rule does not apply to A-kites though. The bottom part of the sail below the foot is referred to as the foot round, and is incorporated into the design when manufactured. Cheers.
Dean M Baldwin
Morgan "D"
Mark III - Hull 516
Halifax, N.S.
Dean M Baldwin
Morgan "D"
Mark III - Hull 516
North Sydney, N.S.
