My first spring on my C&C 27 coming up - Do I need to prime the fuel flow into the carb for the first start - there seems to be a Hand primer on the engine for the fuel so just wondering how to use this for the first start of the season. I know the manual suggests to "Fill fuel pump bowl using the hand primer on the fuel pump" but when do I know its primed, how many pumps, etc...
ThanksPeter Logan
C&C 27 MK III 1975 Tomorrow
LaSalle Park Marina Association
Hamilton ON
Peter Logan
Hamilton ON
Hi,
    You will feel it easily ( after maybe 4-5 strokes , it kinds of stop moving. I do it only when I empty the bowl to remove sediments and look for water ( no more water after I've installed a Racor as the first inline filter.
If you remove the bowl make sure the cork/rubber bowl gasket is tight otherwise an air leak can prevent it from starting..
Sylvain Laplante
La Belle Poule C&C27 MkIII
Sylvain Laplante
