#1 2019-10-24 04:13:41
SAILAVIE
27 MK V rudder structure
Hello C&C'ers
I am looking for my C&C 27 MK V structure, is it steel and foam ? solid wood ?
Thanks for your help
Marc DuboisMarc Dubois
C&C 27 MK V 1988 hull 152
Marina d'Oka
Oka, Quebec
www.SailÀVie.ca
Marc Dubois (SV Geronimo)
Oka, Quebec
Www.YachtingZone.ca
#2 2019-11-05 09:14:57
JWente
Re: 27 MK V rudder structure
It is a Fiberglass outer shell - the join is at the leading edge of the rudder
Top part out of the water is painted white over the fiberglass
I believe the interior is foam
#3 2022-03-31 11:25:57
SAILAVIE
I confirm it is all foam, got a new one and before that I has to fix the old one, it was all foam
Oka, Quebec
Www.YachtingZone.ca
