#1 2015-05-23 15:55:31
doogymon
Folding Prop Installation
Hi.
Picked up a Gori 2 blade and can't figure out how you would tighten it up on the shaft. The nut is housed deep inside the bore and won't slide out.
http://www.ipernity.com/doc/1125763/35981655
#2 2015-05-24 03:11:43
Re: Folding Prop Installation
There's not a lot of info on Gori installations on the web. Does this help?
http://ab-marine.com/Gori/2-Blade-Installation
BTW - make sure you use the specified grade of Loctite or you'll have a devil of a time getting the prop off for service.
#3 2015-05-24 12:20:51
doogymon
Hi David
Thanks for that.
Yes I surfed a few months ago no joy.
Your results much better.
I received the prop post launch.
Crane only shows up twice and the next time will be October.
Was pondering doing a Buster Crabb (MI6)..Doh
That is installing with long snorkel.
I don't think a wrench can wiggle in the small gap.
Loctite on the setscrews. Can that be applied while submerged?
Cheers
doog
#4 2015-05-24 13:06:20
Sensible divers don't take on tasks that involve tiny setscrews on top of setscrews. Nor do they undertake to juggle a hub, a shaft key, a shaft nut and blades. Or Loctite, which doesn't work under water.
Sorry you've missed your installation window, but do it once, do it right – if you've not done it before, folding props are a mental and physical juggling act that need to be done on the hard. Otherwise you end up like a member of my club, who found his new prop had spun off somewhere between Trenton and Belleville.
Not a great role model, Cdr Crabb. More like an admonition.
#5 2015-05-24 14:24:33
doogymon
I think your advice resembles the metaphor!
