#1 2004-11-16 01:07:28
MkV leaking portlight
One of my portlights seems to be leaking - the caulking around it seems to have deteriorated - can I simply scrape out some of the old caulking and recaulk?
#2 2004-11-16 04:13:19
Re: MkV leaking portlight
It's not caulk, it's methacrylate glue, and fixing it is not merely a matter of re-caulking. Read the material on windows in Black Arts.
#3 2004-11-16 09:24:01
Jim
they all leak sooner or later.  It is possible to scrape out the caulk, and if you insert enough new caulk into the gap, it may stop leaking...for a while.  At least, I stopped leaks on 3 out of 4 corners this way.  The fourth corner just keeps leaking.
For a permanent fix your options are 1) remove the window and reseal - see black arts or 2) remove the window and reattach with cement + screws - see balck arts.
Be careful removing the window - on a MKV they are seated on a thick layer of gelcoat, and if you simply pry the window up it will damage the gelcoat.  Try slipping a knife or blade between the window & the gelcoat -and running it down the window to break the seal.   some say a cold day makes it easier. (I wouldn't know - I haven't tried it myself!)
