In replaceing the sink seacock, I ruined the through hull (3/4 pipe 2 3/4 flush flange
I'm hearing that,Ive never seen one with such a wide flange,can't help you. My reply was that I know some people that might
Thanks Dana
Capricous Hull #599
Capricious Mark 3 Hull #599
I never was able to find a replacement flush flange throughull of the right dimensions. Those old ones were beautiful and nicely installed: wish I could have got them out intact too. I ended up having to grind out and rebuild the hull flush, and then mount a standard protruding flange throughull.
Thanks Windy day
I was afraid of that.That expains why the newer seacocks have the big ugly doughnuts on the hull
Capricous Hull #599
Look into the Marelon seacocks and through-hulls made by Forespar.  I replaced all of the seacocks on Carriden and the new ones are all flush-fitting.  The shape and size of the outside flange is different from the original bronze through-hulls, but you can still achieve a perfect flush bottom.  As a bonus, the Marelon seacocks do not suffer from electrolysis and they have proper ball valves, which are visibly open or closed and shut with a quarter-turn.  Do not confuse Marelon with cheaper nylon or other plastic fittings, they are much stronger.
Marcus Opitz,
