#1 2021-03-24 14:50:26
wrapper
Mk III rudder
I've got a spare rudder in my locker... must be dry, it has been there for ten years.
Make me an offer.
Montreal
Allan
Cygnus
C&C 27 Hull 518
#2 2021-05-01 03:53:51
ahighroad
Re: Mk III rudder
Hello Wrapper;
I just became the owner of a Mk I with a badly damaged rudder. Having owned lots of smaller (less than 20') sailboats, this is my first "big" boat. Which is to say I don't have any idea of what a replacement rudder costs for a boat like this. Could you let me know what you would take for it (Assuming it is still available)?
Many Thanks!
Andrew
#3 2022-04-09 23:45:14
brianb
Re: Mk III rudder
its been a year but ill try !!!!! still available ?
1978 c&c 27 mkiii h#726
port stanley Ontario
#4 2022-04-10 00:16:32
wrapper
Re: Mk III rudder
yes it is available  email boats@mrallanwong.name
Allan
Cygnus
C&C 27 Hull 518
#5 2022-04-10 12:58:11
wrapper
Re: Mk III rudder
Allan
Cygnus
C&C 27 Hull 518
#6 2022-04-10 19:13:12
TalW
Re: Mk III rudder
The top of the rudder in the images appears to have been cut down for the rear half of the blade, whereas the stock Mk III rudder had a flat top.  See attached photo of a stock rudder.
Since there's no shot of the whole rudder I can't tell whether the rest of the rudder blade matches the Mk III's relatively deep and high aspect shape.
Tal
ex "Critical Path" 27-3 #632
#7 2022-04-10 21:18:26
brianb
Re: Mk III rudder
yep i thought the same as soon as i saw the pics looks like a mki
#8 2022-04-14 11:33:51
wrapper
Re: Mk III rudder
https://photos.app.goo.gl/bfLbuU2WBH6KArGc8
I have added a few more photos showing the full rudder.
The top part is angled down aft of the rudder shaft.
Allan
Cygnus
C&C 27 Hull 518
#9 2022-04-14 12:47:19
TalW
Re: Mk III rudder
Thanks wrapper, I suppose the top could've been cut aft of the rudder shaft but I can't imagine why.
It's hard to tell for sure because of perspective, but the leading and trailing edges don't look parallel in this image.  If they're not, then this is definately not an original rudder from a MK III (or any other C&C 27).
Tal
#10 2022-04-14 13:16:08
wrapper
Re: Mk III rudder
Going back in time, I bought this rudder from Mike Lohr.  He had his keel stolen and this was his rudder.
I google searched and found this conversation
http://www.cc27association.com/f4/viewtopic.php?id=2019
Allan
Cygnus
C&C 27 Hull 518
