#1 2013-05-06 00:30:40
whippet
A4 Water Pump (raw water) needed in Toronto
Hi
Usual last drama before launch - scheduled mid-week.   Mechanic says A4 water pump housing (raw water, late model) is cracked and need new unit.
Any ideas where to source new or used in Toronto?    I could get from Moyer but i need fast.    Thanks.
TS&CC, 1981 MkIII, Hull 886
Toronto ON
Etobicoke YC, Toronto ON
#2 2013-05-09 04:11:27
whippet
Re: A4 Water Pump (raw water) needed in Toronto
To close loop.   Moyer did an overnight shipment to States and i picked up there.    New pump on boat.
By the way, new pump did seem to solve water in oil problem i was having, at least hope so.  seals had failed on Orberdorfer
Toronto ON
