#1 2014-02-12 11:04:37
Van_Isle
Cutless Bearing
What is the size of the cutless bearing installed on the 27's? 7/8th shaft and what OD?
Mine is a 79 Mk III ...
For the spring haulout it is planned to do the stuffing box (new PSS dripless seal going in) new engine coupling (Moyer split coupling on order), the cutless bearing and maybe a new prop.  Boat's in the water right now so I can't check the bearing for size.
North Saanich, B.C.
Cygnet
North Saanich, BC
#2 2014-02-24 05:45:52
Katara
Re: Cutless Bearing
I have a 1979 Mk 3 and used this bearing
http://www.deepblueyachtsupply.com/marine-bearings/naval-brass-inch-cutless-bearings/ModelNumber/ACID
that being said do i have the same skeg as you do?
Gerard Warner
Katara, '79 Mk III
Bronte, ON
Gerard Warner
Katara, '79 Mk III
D.Y.C.  Ontario
