#1 2007-01-10 06:30:20
Prop Strut - MK III
Hello,
When I pulled my boat for the winter (Racine, WI), I was surprised to find that the bronze strut which supports the propeller shaft was broken.  I never knew I had a problem as everything was still running smooth and nice (I still have the A4).
I have removed the shaft, coupling etc. and am having a new shaft made as the old one was bent.  I am also having the prop balanced.  I am trying to buy a new strut, but having real problems finding one.  I tried South Shore as well as several other sources, all failures.
Any ideas for a source?  Does anyone know of a used source?
Bob Wooden
#2 2007-01-10 08:28:30
Re: Prop Strut - MK III
There was a fellow on this forum who lost his boat to Katrina. He might still have the p-bracket. Search for "Katrina".
Alternatively, take the pieces to a moulding shop and see if they can cast a new one (or even repair the one you have).
#3 2007-01-10 09:01:32
Check out the following site: www.practical-sailor.com. Look through their index for "recasting a prop strut".
Article deals with a situation similar to your problem.
Hope this helps.
Bob Honsberger
Burlington Ontario
former owner of "Budge". hull # 322
#4 2007-01-10 09:08:59
Forgot to mention that new struts are available from
www.buckalgonquin.com. Not sure of cost, but may be less expensive than having one cast locally.
Bob Honsberger
Burlington Ontario
#5 2007-01-11 04:02:14
KenPole
The current issue (February) Canadian Yachting has a display ad for Bayview Propellor Repair in Woodview, Ontario. It indicates that they do strut repair/replacement. They're at <A href="http://www.bayviewpropellor.ca">http://www.bayviewpropellor.ca</A>, e-mail <A href="mailto:bayview.propellor@sympatico.ca">bayview.propellor@sympatico.ca</A> or phone (705) 654-4409. I'd appreciate, as others probably would, knowing how you resolve the problem. Good luck.
#6 2007-01-11 12:37:27
KenPole
As Administrator Dave has pointed out, the URL for Bayview Propellor isn't working. I know, I know, I should have checked it before forwarding it. However, it is as printed in CY so will follow up by phone tomorrow and advise. Cheers.
#7 2007-01-12 01:59:18
KenPole
Further on Bayview Propellor. Proprieter Dennis Johnston confirms that their website is down and that they're looking for a new ISP. Meanwhile, if you have no luck locally, their e-mail address and phone number in the earlier message are current. Johnston says they can repair, replace (if they have an old one) or recast. Over to you -- and, again, good luck.
#8 2007-01-12 08:38:00
Thanks to everyone for the good ideas and information.  I'll update when I have an outcome...  Only about 84 days until launch if I can get everything done!
#9 2007-02-13 08:52:06
I have a prop strut from my 1976 25. According to my original owners manual it is for a 7/8" shaft which appears to be the same shaft used in the 27 with an Atomic Four.
Drop me a note. Stephen   s.s.harding@sympatico.ca
#10 2007-04-26 20:53:19
WIGMAN
hi bob let me know if you still need that strut
#11 2007-04-29 00:15:50
woodenr
erdana">Time for an update...</SPAN>
erdana"></SPAN>erdana">I started this thread, looking for a prop strut to replace the broken one.  Here is the run-down on what all has been done (I am ready to launch next week).</SPAN>
erdana"></SPAN>erdana">- New Prop strut was cast by Mystic River Foundry in CT, using the old one as a pattern.  Seems like a quality casting, but I should have done my own pattern work.</SPAN>
erdana"></SPAN>erdana">- Machining of strut and new shaft (old one was bent when checked) by Air Marine in Chicago.  Also fitted new coupling to shaft.n: yes">  </SPAN>Great work.</SPAN>
erdana"></SPAN>erdana">- 11X5 Martec prop fitted.  This was a used prop that I had rebuilt by Martec; it looks like new at 1/4 the cost of new.n: yes">  </SPAN>This is the older “flat tipped” Martec with more blade area near the tip than the newer elliptic.</SPAN>
erdana"></SPAN>erdana">- New shaft log hose, packing etc.</SPAN>
erdana"></SPAN>erdana">Basically everything is new from the back of the old A4.n: yes">  </SPAN>I’ll close this thread (since I started it) and report on how this prop works compared to the previous 12X5 Michigan "blue dot" folder".</SPAN>
erdana"></SPAN>erdana">Bob Wooden | </SPAN>erdana">Rhapsody – C&C 27 Mk 3</SPAN>
